anyone heard of this dvd with vga ????
Discussion in 'Blu-ray & DVD Players & Recorders' started by gizlaroc, Jan 8, 2003.
  1. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Daewoo player with vga, qanyone heard of it ????
    can be found here , and does pal/ntsc with hack.
    not looked at players for ages but just stumbled on this and wanted to know if anyone has had any experience with.
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    never mind, just read on avs that it is a bag of nuts :)
  3. Jonny1973
    Jonny1973
    Ages ago there was a lot on here about a Nintaus player that had VGA out but there were a few bugs with it. Most people who had one returned them.
    There was also a Skyworth player.
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    i have seen the skyworth and that was pretty good for the money.
    just stumbled across the above and couldnt find any info, didnt realise it was quite old.
  5. Jonny1973
    Jonny1973
  6. jmack
    jmack
    i just bought a dvd player with progressive vga out it was the arianet it was 79.00 and was crap
  7. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
    I have a Nintaus DVD-N828 with VGA output and Zoran Vaddis 5 chip,I haven't tested it yet, as I'm waiting for my receiver.
    In China Nintaus is one of the biggest and it is regarded as the best one at the moment, and these new generations of DVDs (if you go to www.nintaus.net and choose chinese when you enter and choose the dvds dropdown menu, you will see they have quite a wide range of players) are much better now and the design is as good as Japanese ones.
    http://www.nintaus.com/chinese/prducts/dvd/868.htm
    http://www.nintaus.com/chinese/prducts/dvd/828.htm
    N868 has the new Zoran Vaddis 6 chip (www.zoran.com), dvd-audio and vga output, with a design that looks like the panasonic/jvc (maybe it is the same)
    For all forum readers, Zoran chips are actually in Pioneer/Toshiba/Arcam/Samsung/Sharp dvd players so it can't mean that it is that all bad.
    Wasabi
  8. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
  9. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    +32
    MontyUK, It should be the same as N868, however, I am not sure if it has the Sage chip or in any other models except for 9769 as it is not mentioned on their website, it might only use the Zoran Vaddis 6 chip as it is a all in one integrated chip as this link reports, http://www.zoran.com/whatsnew/07_09_02.asp
    Regarding the drive problems, it seems isolated to 9769, as the 800 series doesn't seem to have had any problems ( I have also had a N818 before this one).
    The price for the N828 was converted to sterling £80, which is extremely cheap as it is definitely at least as equipped as the Limit9000se if not better as it has VGA out.
    Have you enquired what the N9868 price is in DKK? I think the price for N868 is around £140, and I would guess that the Danish price in sterling would be at least £250.
    Wasabi
