Anyone heard of AVF Hi-fi stand??
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by edlomb, Oct 19, 2004.
  1. edlomb
    edlomb
    Sep 8, 2004
    48
    While on the search for hifi stand I came accross a stand made byAVF.
    I found it at Comet. Here's the link: http://www.comet.co.uk/comet/html/cache/154_855471.html
    Has anyone heard of them.
    I am trying to find a good hifi stand for about £100-£150 (all that my budget allows). I figure used is my best bet.
    Eddie
  2. AMc
    AMc
    Nov 20, 2000
    7,020
    Near Norwich
    +3,655
    I have an AVF speaker bracket holding up my Projector. They're just a normal brand IIRC I got mine from Argos.
    I would post a want ad in the hardware classifieds here and see what turns up.
  3. F1Boy
    F1Boy
    Jul 14, 2004
    198
    Fareham, Hants
    +13
    Don't know about racks but I've got a pair of these.
    I know it's not much help as they're speaker stands :confused: but they're AVF and seem pretty well constructed - certainly as well as the Alphason ones I looked at. I probably go for it and give it a try :smashin:
    Good luck,
    Matt
