Anyone have the Creative DDTS-100 decoder for their PC?
Discussion in 'Home Cinema Speakers' started by dmuk, May 19, 2005.
  1. dmuk
    dmuk
    Does the DDTS-100 have problems with DivX/Xvid files that are encoded with AC3?
    Power DVD will pick up a true DD signal for a DVD, but if i convert to avi (divx) with the ac3 sound, it only uses Pro Logic II/Neo6. There isn't even the option in Power DVD to use spdif when playing an ac3 divx file.
    Who here has the DDTS-100 and can play AC3 divx files fine with TRUE DOLBY DIGITAL?
    Cheers.
  2. dmuk
    dmuk
    Turns out it'll only pick it up if the divx file is converted to DVD vobs.
    I use vso divxtodvd
