I look for a high number, 200, 300 is where I've had great success. I think the Ice amps are much higher than that.
I have had high power class D (some good, some bad), Mosfet (didn't work for me) and I use regular A/B power amps now, albeit high wattage with very large transformers in, that work very well.
I struggle to hear the difference between my expensive power amps in the cinema and my crown amps when driving the same speakers. Maybe my pre is lacking in that set-up, I don't know. Maybe I have cloth ears!
Thanks Conrad. Interesting on damping factor. For my Rotel RB1050 it says it is 500 in the specs and that's not even class D.
A lot of members seem to be of the belief that all a good power amp is is based on power ratings and all done - that the pre-amplification is the vast majority of what's making the sound experience.
I disagree, if just subjectively. For decades of course like most of us I've had many different integrated and AV amps and noted the differences between them but that has been changing the (integrated) pre-amp too. Only recently have I had the chance to use the same pre-amp with different power amps. The subjective differences I note (not in any order) are:
1. Stereo separation and stereo "placement". The sounds are placed more accurately across the soundstage.
2. "Sound clarity". Sounds become clearer and more pronounced. Using one power amp compared to another, some of the sounds are different. And you hear some sounds that you may not have heard before.
3. Hardest to explain. An ability to make multiple sounds at the same time. Complex music where there is a lot going on, a rubbish power amp can sound "muddled" like it is overwhelmed. A better power amp almost sounds like it has different channels making each sound for you. (I know it doesn't, I'm just describing it).
Tracks that I have personally found exhibit well some of these differences (specifically numbered):
1. Buggles - Video Killed the Radio Star. Duran Duran - Planet Earth. Human League - Darkness. Snap - The Power.
2. Kraftwerk - Radioactivity. Cabello/Mendes - Senorita. Mason Williams - Classical Gas.
3. Supertramp - School. Kansas - Wayward Son. The Prodigy - Charly (from the remastered album of Experience, think it's track 6). Duritti Column - Sketch for Summer.
I think it's relevant to note these, as I'm just making the point that the power amplifier does make a difference. What are your thoughts?
