Well that was a successful request.
So, having taken delivery of one today here's my thoughts:
It's crap!
1) Clips to retain glass in front panel were missing.
2) Cracks in the veneer that have been filled - with orange paint! And this is on the top of the unit, in plain sight.
3) Despite the glass being stamped October, it has the old style door mechanism. This renders the upper AND lower shelves useless for full width kit.
4) Despite claims of real oak veneer, the edges of the door look & feel suspiciously like printed paper.
5) The castors don't work even on my soon to be replaced, flat as a pancake pile carpet.
6) The frame of the door is so wide that stacking kit in an attempt to gain some usable space means displays/IR receivers are hidden.
7) Given that I loaded it with the glass missing, I can't see how the hell you'd do it with it in place. Unless you cut huge holes in the back panel or omit it altogether. I was forever putting a hand or knee down where the glass would have been.
Apart from that it's fine.
I'd have been
off if I'd paid £50 for it, never mind £200+.
The search continues...
Edit
It's not a great match for the RS6 speakers. The veneer isn't a patch on MA's (even without the paint
Another Edit
It seems as though the unit does have the correct door mechanism. Confusion caused by Alphason's poor use of English. So when they say:
Specification of the door closing mechanism has changed to the one pictured. Top shelf is no longer restricted by the assembly.
What they actually mean is "Specification of the door closing mechanism has changed
from the one pictured. Top shelf is no longer restricted by the assembly (
as long as you only fit the shelf in it's highest position)."
I wonder how hard it would have been to have made it the ABR1150 so that the door mechanism had no impact? Muppets.
