Anyone have advice on the Marantz 4200 with Tannoy 633s please?
Discussion in 'AV Receivers & Amplifiers' started by Taz69, Apr 20, 2002.
Tags:
  1. Taz69
    Taz69
    Apr 15, 2002
    3,481
    Bristol
    +356
    I have a Marantz 4200 on 2 weeks trial from RS, (nice chaps),the dvd player is a choice between a Panasonic A350 MR or a Pioneer DV340 MR, I am using Tannoy 633s as my Front Pair with a Mordant Short 905c Centre and MS Bipole rears, my problem is there seems to be a lack of bass although present not overwhelming, also the Tannoys seem to be very low with most of the Dialogue coming from The Mordant Centre. The link between the DVDs is Coax.
    Any Advice welcome, even if it means I have to go back to my Technics SA-AX7, forget DTS and get a Sub or different Front Speakers.
    Thanks in Advance
    Taz
    Home Cinema Kit
    Panasonic 36D3DPL
    Panasonic SVHS800
    Panasonic A350 MR DVD via Coax
    Pioneer DV340 MR
    Marantz SR4200
    Cambridge Audio Coax & Optical Cables
    Tannoy 633s connected via Cable Talk Talk3
    Mordant Short MS905c via Gale Cable
    Mordant Short MSB20s Bipoles via Gale Flat cable
    Sony PS2 via Optical cable when in use
    Panasonic Sky Digi Box
