Anyone have a spare Anchor Bolt ?
Discussion in 'Home Cinema Buying & Building' started by smallangryboy, Dec 31, 2006.
  1. smallangryboy
    smallangryboy
    May 5, 2003
    2,003
    +82
    I've just got back from a rather harrowing journey to the local DIY centre for two packs of Anchor Bolts to mount my Plasma panel, M6 size x 60mm long.
    I've just realised that one pack has some missing. As I've opened the packs I think they may be a bit shirty about a replacement, and so I wondered if anyone had a bolt of similar size they could spare ?
    cheers
  2. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    Think so, will have a look!
  3. smallangryboy
    smallangryboy
    May 5, 2003
    2,003
    +82
    Sean thanks for the reply and the offer, I've checked and it seems 6 will be more than enough to hold the bracket and TV safely.
