Anyone have a Panny TH-37PE30B with TYS37PX20W stand yet?
Discussion in 'Home Cinema Buying & Building' started by grumps, May 19, 2004.
  1. grumps
    grumps
    May 7, 2004
    168
    28
    +49
    If so could you do me a real favour and measure the shelf heights on the stand, and or tell me if they are adjustable at all? I am thinking of taking the plunge into Home Cinema and want to know if my Dynaudio 42 C Center Speaker will fit on the shelves (it's about 15CM High). I did call panasonic but they gave me only depth and width!
    By that way Unbeatable seem to have about the best price on this stand (£344.96)
    Much obliged if anyone can help
    :lease:
  2. joemack
    joemack
    Apr 30, 2004
    22
    3
    With the shelves equally spaced, the gap is 12cms. However the lower shelf has two fixing options - the upper one makes the gap between the base and first shelf 18cms, but results in the gap between the two shelves at only 6cms(a tight squeeze to fit anything on the lower shelf). Hope this helps since I had to get out of bed to measure it.
    Regards
    Joe.
  3. samhain
    samhain
    Apr 1, 2004
    2,786
    South West Scotland
    +131
    That's service for you ! :D
  4. grumps
    grumps
    May 7, 2004
    168
    28
    +49
    Thanks Joe your a Star! :thumbsup:
    By the way , are you pleased with your TH-37PE30B and would you recommend?
    Thanks Again
    Grumps
  5. joemack
    joemack
    Apr 30, 2004
    22
    3
    Having seen the PA20 model in JL and Comet, can't say I was impressed with PQ. However when I tried out the PE30 at Powerhouse, after many months of searching, this was the ONE.
    Now that I have tried it at home, I've definetly no regrets in going for this one.
    mmmm........ Well maybe that I didn go for the 42" screen.
    Regards
    Joe.
  6. grumps
    grumps
    May 7, 2004
    168
    28
    +49
    Think I'm going to place my order for one now as general opinion of these is good. I will go for a pedestal stand though and maybe an Alphason rack to put it on as I don't want to pay nearly £400 for the panasonic stand if I can't fit my centre speaker on it easily.
    Cheers again
