Anyone have a ccf file for DV79?
Discussion in 'Arcam Owners' Forum' started by jimcarney, Jan 17, 2005.
Tags:
  1. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    For the Pronto RU 940 ,I have tried Remote Cenrtal they only have ccfs for DV88.
    Jim
  2. LameBolus
    LameBolus
    I ran into the same problem. For kicks and giggles, I loaded the DV88+ into my remote, works fine with the DV79. I used the 88+ from Dean and it is running my HTM MX700 fine. Try using a DV88 first.
    Lame
  3. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    Jim, I think all the codes for the ARCAM DVD players are the same. Have you tried the DV88 one?
    Andy
  4. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Thanks guys !....Jim
  5. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Yup, the one I posted for DV88 at Remote Central should do fine. None of the more recent Arcam players add any new discrete codes AFAIK.
    Dean
