Anyone had experience with Tekaloid/coachpaint?Painting a horsebox
Discussion in 'Motoring' started by Oily, Jun 14, 2009.
  1. Oily
    Oily
    Jun 11, 2007
    1,062
    Radcliffe
    +83
    This has been a long on-going project and i'm at the stage were i feel it needs the paintwork sorted.
    So far i've changed both axles over from drums to disc brake axles,changed the lower skirts for ally as the GRP panels were damaged along with the metal box section it was attached to and re-fitted the kitchen etc
    So i found out about Tekaloid from the good 'ol 'tinterweb.Tekaloid seems to fit the bill as i can use a brush and roller and get a good result(from what i've read)as i can't afford to have it sprayed :(
    http://www.amerondirect.co.uk/sheets/ameron/Tekaloid.pdf
    I'm just after some tips/advice on preparation etc off anyone who has had experience with Tekaloid or coach painting in general :thumbsup:
    I've found this site Vehicle Painting Pointers which has some helpful hints/tips but would like to hear other peoples views/experience
