Anyone got the Whistling sound fixed on their PV500
Discussion in 'Plasma TVs Forum' started by pwood, Aug 31, 2005.
  1. pwood
    pwood
    Dec 6, 2003
    2,569
    Central Scotland
    +163
    I have read the stickys but of those that have this fault with their 500's I've not read of anyone getting it fixed. For sure a replacement may be an option but to be honest the PQ is stunning on my set and I'm reluctant to get a replacement if its an easy fix. Engineers have been out and whilst to them its probably within tolerance they agreed that its annoying and are contacting Panasonic to see if they are aware of this issue. I just wanted to hear from any fellow 500 frum members who have had this resolved.
  2. mork80
    mork80
    I've asked local Panasonic support to fix the whistle in my house (I want to avoid replacement or picking up for this fix). I'm waiting a response from them....I'll post here if a good solution will be found...
  3. pwood
    pwood
    Dec 6, 2003
    2,569
    Central Scotland
    +163
    Cheers I will do the same when I get a resolution.
