Anyone got S/PDIF passthru working on a A7V8X?
Discussion in 'Desktop & Laptop Computers Forum' started by Underscore, Mar 31, 2003.
  1. Underscore
    Underscore
    The HTPC is now coming together quite nicely but I still have the problem using the S/PDIF output with TheaterTek. It is fine until I interrupt the playback by pausing, chapter skipping, etc., at which point the video will fast forward for a few seconds before going back to normal - a couple seconds ahead of the audio. I've upgraded to the latest RealTek drivers (3.41) and have just received the files to patch my .18 download of TT1.5 to .23, to see if that fixes it. I'm curious to know if anyone else has managed to get TT1.5 working with the A7V8X, and what drivers you are using?
    Failing this, I guess that forgetting about the on-board sound and installing a known good card is the way to go. I see that the SBLive! 5.1 is ~£25 inc VAT and is what TT suggest. However, the SB 4.1 Digital is about half the price and I don't need the additional features that the Live! provides. Does anyone have it working with TT1.5?
    TIA,
    _
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    My brother is using the A7V8X with realtek drivers and Theatretek but I'll have to get the versions but AFAIK they are the drivers on the install disk for the soundcard and 1.5.23 for theatretek.
  3. Underscore
    Underscore
    Interesting. I think the Asus install disc has the 3.32 drivers. Could you ask which output device he is using for TT? I'm using the default waveout at the mo', though the driver specific DirectSound also worked - but had the same problems IIRC.
    Thanks,
    _
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I think it was direct sound.
  5. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    My deluxe works fine with the SPDIF out, straight out of the box.
    Sorry do not know drivers etc, just getting into this HTPC.
    Rgds
    Nathan
  6. Underscore
    Underscore
    Deluxe? Have you got the A7V8X or the A7N8X? The latter is fine, I've been told, but I've (since buying it) heard of a number of problems regarding S/PDIF and the former. Guess that it's something to do with the VIA chipset since I think that they both use the RealTek sound...
    Cheers,
    _
