anyone got razer thresher ultimate xbox one headset?
Discussion in 'Xbox One Accessories' started by madformusic, Aug 6, 2018.
  1. madformusic
    madformusic
    May 25, 2009
    368
    28
    +31
    i'm thinking of getting them and wondered if anyone has them and the opinions you have of them?
    got astro a50 gen 2 but mic isnt very good and playing up so thought about the razer thresher ultimate edition for xbox
  2. N0ddie
    N0ddie
    Jun 15, 2010
    1,063
    Glasgow
    +413
    Why do you need the Ultimate edition over the standard edition? @sparkymark75 has one and from being on the other end of the mic, its sounds very good.
  3. sparkymark75
    sparkymark75
    Jan 6, 2003
    3,237
    Fife
    +747
    The ultimate edition has a dock which you can use to recharge the headphones. If you plan to use them with a PC, then they will work with that too. I bought the "Essential"version simply because they are cheaper and you don't need 7.1 headphones to get surround sound. Just use the Windows Sonic or Dolby Atmos apps for that.
    If you want to use the "Essential" version on PC though you have to buy the Wireless adapter for Windows 10. But it's still a massive saving over the Ultimate edition.
  4. madformusic
    madformusic
    May 25, 2009
    368
    28
    +31
    how do you find the sound quality and mic at all? any opinions you have? do you have an comparisons against the astro a50 at all comparing both?
    was thinking of ultimate just to save hassle and the dock and 7.1 and i'm all set and no need to worry
  5. sparkymark75
    sparkymark75
    Jan 6, 2003
    3,237
    Fife
    +747
    Sound quality is great. I sometimes get intereference but then that’s a risk with any wireless headset. @N0ddie will be able to tell you the quality of the mic.
