Anyone got or seen the Sony HS2?
Discussion in 'Projectors, Screens & Video Processors' started by Bristol Pete, May 24, 2003.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    I now find myself projector less.
    Refer to my earlier post.
    Presently considering my options, and looking at back issues of What TV etc I note that the HS2 has a reasonably good review.
    So anyone out there got one in or even demoed it...?
    If so what are the opinions available?
    I may take a look at one tomorrow.
    Regards,
    Captain Benefit.
  2. Ghidorah
    Ghidorah
    Oct 16, 2002
    143
    19
    Bristol
    Hi Captain,
    I had the HS2 awhile ago and thought the picture was a bit blocky and you could see a bit of screen door. But still not that bad.
    Then I had the HS10 But that started the good old start up prob after 4 hours so that whent back.
    Now have the Pana AE300 and think it nearly as good as the HS10. And it is nearly silent next to the HS10.
    If you can afford it I would recomend the Pana 300
    Good luck with your choice
    Ghidorah:D
  3. Ghidorah
    Ghidorah
    Oct 16, 2002
    143
    19
    Bristol
    Me Again,
    Just noticed that you are in Bristol as Radfords on Gloucester Rd
    Have a demo unit that I have just taken back
    Ghidorah
  4. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    As you can see i'm from Bristol also....
    Is radfords the best place for demo's of Projectors.......i think they're a bit dearer then oher places not true ?
    Do you know of any ohther places in Bristol where i can demo Projectors ?
    What do you think the chances are that radfords will loan me an AE300 (if they have it)...... ??
  5. Ghidorah
    Ghidorah
    Oct 16, 2002
    143
    19
    Bristol
    Hi Fjorko,
    Radfords had to order my Ae300 in so they have not got any more!
    I think Good Viewing at the top of Gloucester Road are getting some in about 2 or 3 weeks
    Sevenoaks on Blackboy Hill have some PJs on demo I think one was the Infocus x1. As do the
    Hi - Fi shop on Park Street but I cant remember the name or what Pjs they were.
    Paul Roberts only do the Dreamvision CineX1 Pj but I did not think it was that good as I saw plenty of rainbows
    As you can see I went all over Bristol looking for demos.
    Hope this is of help.
    Ghidorah
  6. Captain chaos
    Captain chaos
    Saw a HS2 running, lots of screendoor...
  7. Kramer
    Kramer
    Only HS2 I've seen was in a local branch of Curry's - 3 stuck pixels, loads of screen door etc...
    Not very flattering :(
    TBH, there's far better to be had in the guise of the AE300/Z1 etc...
