Question Anyone got LG 32LM6300PLA best screen settings?
Discussion in 'LG TVs Forum' started by james_uk, Jul 19, 2019.
  1. james_uk
    james_uk
    Jul 8, 2009
    57
    Hi Just got this TV for the bedroom, cheap and not a bad picture to be honest.
    I've had a mess around and theres just something i'm not sure about with the picture, I wondered if anyone else has got any recommended settings for it?
    James
  2. Mad Ant
    Mad Ant
    Jan 29, 2019
    218
    Croatia
    +39
    That one is HD-Ready, meaning 720p so lower resolution than 1080p. Is that what is bothering you? We need more info to help you...
  3. james_uk
    james_uk
    Jul 8, 2009
    57
    Hi, no i was meaning the collaboration settings, so the best setting for colour and viewing, what are the best settings to have on and off, contrast etc
    I just thought there maybe some for this TV as well, i have another tv, Samsung ks8000 and on that forum there are recommended settings for it for best picture setup.
  4. Mad Ant
    Mad Ant
    Jan 29, 2019
    218
    Croatia
    +39
    The low-end ones never have that, you just go by your eyes. For color calibration you need pro tools like CalMan and a camera/sensor.
    You can use the cinema mode that should be factory calibrated for colors, but is darker for dark room viewing so up the brightness/backlight.
    All other settings have a short explanation what they do. Usually it is recommended to turn off eco settings (eye strain settings etc.) and some people don't like noise reduction/mpeg filters, but that depends on the quality of material watched...
    And don't expect that model to have picture quality like the big boys :)
    You can go to RTINGS.com and read through settings for UK6300 for example since they explain what they do.
    LG UK6300 Calibration Settings
  5. james_uk
    james_uk
    Jul 8, 2009
    57
    Thanks mate i will just go by my eyes then :)
