anyone got discrete input codes for HS50?
Discussion in 'Projectors, Screens & Video Processors' started by Jules, Jan 17, 2005.
  1. Jules
    Jules
    Oct 11, 2000
    5,099
    +772
    Damn, the discrete remote control code that I used on my HS20 to switch to its component input doesn't work on the HS50.
    I'm using a Marantz RC9200 remote (same as Pronto).
    Anyone got the correct code for the component input? All the other discrete codes e.g. on, off, S-Video etc all work fine. I just need the component code as part of a macro.
    Thanks.
  2. Jules
    Jules
    Oct 11, 2000
    5,099
    +772
    Solved my own problem.
    The code from my old Sony VW11 for 'Input B' works just fine for setting the HS50 to its component input.
    For anyone with a Philips Pronto type remote control, here is the code.
    0000 0067 0040 0000 005c 0018 0018 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0362 005c 0017 0018 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0361 005c 0018 0018 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0361 005c 0017 0018 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018
    Hope that's useful.
  3. tomos
    tomos
    Oct 3, 2004
    135
    16
    you have to type all that in? :eek:
