Quantcast
Anyone got an extra VGA input board on their Panny 6 ?
CARLOS
If so when you use the PC button on the remote does it toggle between both VGA inputs ?
loonatic
I haven't but I'd guess that it would not work like that...the second VGA input would simply be either input 1,2 or 3 depending on which slot it was in.
Cheers, Lee
CARLOS
Cheers, Lee
Thanks for the reply, I thought that would probably be the case !
nickc
Cheers, Lee
Yes i've got one and that's how it works.
Similar threads
