Anyone got a Sony CDX-M9900 ??
Discussion in 'Video Streaming Boxes & Services' started by cracker, Sep 4, 2005.
  1. cracker
    cracker
    Sep 4, 2005
    2,055
    +246
    Does anyone have one of these Sony M9900 headunits?
    I'm just wondering what the options are for the image-capture function... Can you only capture from the video input or can you upload image files from a CD-R or maybe some other cunning way... ?
    Any help appreciated! :)
  2. KROKIS
    KROKIS
    Only capture from AVinput-RCA.
  3. cracker
    cracker
    Sep 4, 2005
    2,055
    +246
    Ok thanks for that
    I think i should be able to capture images from my DV video camera as that can store images on an SD card and output them via the RCA output as a slide-show so i should be able to capture the images from there
    Just another question, is there a best size/dimensions for the image to ensure that the image captured fits the screen nicely?? (it seems the screen is quite wide and not very tall). At a guess it seems the aspect ratio would be about 5:1
