Anyone got a Sharp 30HV4E....?
Discussion in 'LCD & LED LCD TVs Forum' started by PhilipH, Oct 22, 2004.
Tags:
  1. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    ...and could try something regarding the serial port for me?
    I'm trying to find out whether that model uses the full Sharp serial protocols which allow serial commands for power on and power off and I have no local dealer who I can ty it myself at.
    Phil
  2. RichardP
    RichardP
    I've got one, but I have no idea how to send it a command via the serial port, you will have to tell me exactly what to do (I know my way around a PC just not the Sharp serial protocols).
  3. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    Ahhha! Cool...
    ...basically Sharp have a load of discrete commands so that you can make your set do exactly what you want via a serial port - choose a specific AV input, choose a specific display aspect ratio etc. - without you having to use toggles which can get out of sync very easily.
    They also have "Power On" and "Power Off" commands - which is great except that the "Power On" command doesn't work as when the set is in Standby mode then only the IR receive circuits are live and sending a Power On to the serial port is just ignored.
    I have found a command which keeps the serial port alive so you can wake the TV from its slumber by a serial port "Power On" command and I got confirmation from a mate last night that it works with his 32GA4E (I think) - I just want to find out whether it works on the 30HV4E (which is one of several sets I'm looking at).
    If you're up for trying this out then run me through a Private Message and we'll talk by email ... I have all the serial port protocols here so hopefully it should be easy and quick enough to test.
    Phil
  4. RichardP
    RichardP
    Phil,
    Sorry, I didn't read your post correctly, I have a G37HV4E not the G30HV4E. I don't know if that's still of interest.
    I can tell you that it does respond to IR discrete commands, I use them all the time.
    Let me know if you still want me to test something.
    Richard
  5. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    I think I've settled on the GA4E model (just trying to decide between the 32" - which I want - and the 26" - which is £500 cheaper) - I know that the GA3/4E series will do what I need.
    Thanks very much for the offer of trying the serial comms though...
    Phil
