Anyone got a Panny SCHT900 or another HTX00? and Sky?
Discussion in 'Home Cinema Buying & Building' started by coolio, May 18, 2004.
  1. coolio
    coolio
    Dec 31, 2003
    217
    +4
    Got problems with my Panny SCHT900 when I hook my sky digibox upto it. On surround sound it comes thru all distorted. How should I be hooking it up? Anyone else got this system hooked upto sky?
  2. coolio
    coolio
    Dec 31, 2003
    217
    +4
    come on guys, someone must have this home cinema system and sky
  3. Ianc
    Ianc
    I'm getting a SCHT500 tomorrow and will be wiring it up to sky+ and my panasonic Plasma so I'll let you know what goes on with that... You sure youre not getting interference from cables - the plasma screen I got ( dont know if you got plasma) came wiht a whole stack of ferrite rings to go on spkr etc cables to stop interference - liek the suppressors you get to go on car stereo power supplies to stop engine interference.
  4. coolio
    coolio
    Dec 31, 2003
    217
    +4
    The thing is its fine on everything else, normal TV, dvd, etc just the sky, but its normal sky, im guessing u will use optical out with your sky +
    Let me know how u get on tho, say with sky one, what sound setting u have it on
  5. Ianc
    Ianc
    Ok
    so Ive got a Panny SCDT310e i know its not quite the same...
    Use digital out from Sky+ box to digital optical in on the panny amp.
    In sky I've set , in the sound menu, the output from Normal to Dolby, its on Stereo. I thin krest of it is same.
    If you've only got sound knackered from certain channels intermittnetly I'd suspect a cable. The amp will be ok because its getting sound processing correct on other sources ( like DVD's I assume).
  6. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    i'd personally just link your tv to your HT system through analogue phono interconnects. that way, whatevers playing through your tv, will come through your HT system, through the ProLogic II.
    other than that, sounds like a faulty unit
  7. coolio
    coolio
    Dec 31, 2003
    217
    +4
    I have hooked up the SCHT900 is so many different ways and the problem still exists
    The only time it doesnt is when its on 'Party' or MPS1 or MPS2 but i dont like that sound effect, doesnt want to work at all with DPLII at all.
    Ive done it thru the TV using scarts, used phono cables into various different ports in the amp. Still always the same results so today dixons (God help me!!) are coming out to take a look at it.
