Quantcast
Anyone got a diagram to connect TV/DVD etc
sswf224
Hi all (again).
Here is my setup - but behind the TV its a mess - so thought about tidying and starting the connection of everything again.
But I cant find a diagram.
1) TV (2 scarts , 4 hdmi's/and of course the red/yellow/white AV's)
2) SKY HD
3) DVD player
4) Wii
5) PS3
I really would like an idiots guide - ie
TV scart 1 to DVD
That would be really helpful
Many thanks
Ross82
2) SKY HD: hdmi 1
3) DVD player: hdmi 2 or scart 1 (depending on connection type)
4) Wii: RCA (red/white/yellow) or scart 2 (depending on connection type)
5) PS3: hdmi 3
Guessing of course sky hd would be the most used.
Otherwise move ps3 up in place of DVD etc etc
no diagram. I'm on my phone.
No need:
SKY HD - via HDMI
DVD player - via HDMI or Scart. (I would maybe remove the dvd player as your PS3 can play dvd's).
4) Wii - via the connection cable that came with it. I think its a scart adapter.
5) PS3 - via HDMI.
If your TV and everything else are on a stand I would remove all the cables that connect each device and then do each one at a time.
sswf224
Thanks very much - thats brill - if I wanted to add a Sharp Soundbar - would that just be Av out on TV to Woofer Box ?
Joe Fernand
AVForums Sponsor
It all depends on the Soundbar and the TV!
Its best to work on actual kit specs rather than general assumptions.
So Make, Model and a link to Tech Spec/User manuals for your DVD, TV and proposed Soundbar would be good.
Joe
Similar threads
