Anyone got a Denon AVR-2802?
Discussion in 'AV Receivers & Amplifiers' started by tee, Feb 25, 2002.
Tags:
  1. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    So what with the current (lack of) availability of the 3802 and the state of my finances, I've decided to go fo the slightly cheaper AVR-2802.....
    Anyone got one? Any comments? Anyone know the best/cheapest place to buy one?
    Cheers :)
  2. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    Surely it's not only 3802 owners in here!? SOMEONE must own a 2802..... Anyone!
  3. Guest
    HI.
    YEAH I`VE GOT ONE.DIN`T WANT TO SPEND EXTRA CASH ON THE 3802 SO WENT WITH THE 2802.I THINK ITS A SUPERB AMP AND GLAD I WENT FOR IT.EASY TO SET UP AND PLENTY OF POWER.
    LOWEST I`VE SEEN IT FOR IS £499
    WWW.LECONCEPTS.COM
    CYA.
  4. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    tee.. excellent amp, well worth it.. and not much difference in spec between it and the 3802... mainly 105w v 90w power and 1 versus 2 outputs for rear centres.
    also some previous threads on this subject.. look for the 3802 2802 or similar and you should find a lengthy discusssion.
  5. Dan5
    Dan5
    Yep I got a 2802 and I'm happy with it more than enough power for my room and I'm sure that meny other parts of my system will need improving before the amp does.
    Dan
  6. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
  7. Dr.Rock
    Dr.Rock
    Jan 10, 2002
    694
    London, UK.
    +38
    I have one too and more tha satisfied with it. I believe the recent What HiFi magazine erviewed it and gave it a full 5 star rating.
    I didn't want to spend extra cash for the 3202, because I didn't feel I'd be using the extra benefits. I'd rather spend the extra £150 or whatever on better quality cables, etc, rather than on the extra 15W and 7th speaker output (which I won't need for now) and then find out I don't have enough money for good interconencts (which defeats the purpose of buying a Denon amp if bottlenecks are just going to impair the performance). Besides, the 2802 does have an upgrade port if decided later on that you want the 7th channel.
  8. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    Thanks for all the comments - I'm sold :D
  9. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    2803 will be out soon :D:D:D:D
    Only joking!
    All the Denon amps are superb.
  10. Timmie Boy
    Timmie Boy
    Jul 16, 2000
    54
    I'm still using 2 yr old Denon avr2800 and it still does the business. Its only got DTS & Dolby 5.1. No pre-outs for rears though but even now I can't see why I would need them.
    I would definately go for another Denon, just because of great build quality and it has never let me down.
    Rock on Denon!
  11. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    btw, Mission recommend wiring up rear centres in serial if you only have one output on your amp.. assuming your amp can do it.. should be fine on a 2802.
