Anyone got a Cambridge Audio M1+?
Discussion in 'Home Cinema Control & Remote Controls' started by raven219, Mar 13, 2002.
  1. raven219
    raven219
    Mar 5, 2001
    532
    East Angular (near Tunisia)
    +15
    Saw this in Richer Sounds. Look like it will do what I want which control the TV, DVD, Amp and CD with some basic macros.
    Any opinions - good or bad?
    Raven
  2. laurel
    laurel
    I've got one and it's fine for your basic operations.
    Macro's are good for adjusting muliple devices.
    You can customise the screens by removing/adding buttons, but you can't change the icons/text on them.
    It's no Pronto - but hey - it's a third of the price! :D
    If like me you want to have all your basic kit functions to hand in one unit - this does the job.
    Laurel
  3. Guest
    Sorry to disagree laurel but the icons can be changed, only approx four to choose from on each button. Easy to program,works well.
  4. laurel
    laurel
    HIGGY
    I stand corrected squire. :blush: :D
    But how do you do it?
    I lost the little booklet that came with it. Well I say booklet... it was a scrap of paper really.
    Don't generally need to instructions though, it's pretty easy to figure out (apart from the button change obviously!)
    Laurel
  5. Guest
    Hold down the device button you want to change for three seconds, then you get the four flashing numbers. After you have keyed them in just scroll through the icon choices by touching the relevant button then press the device button again to store.
    Hope this helps
  6. burkey
    burkey
    I had one for a year and it worked well.Then it lost all of the codes that I had put in ,and would not re learn any more. I then bought a pronto ,mmore expensive but worth it in my opinion.
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    I have both M1+ and pronto (Marantz version). Both are good. The Cambridge is particularly sturdy and feel it was £80 well spent.
  8. mjn
    mjn
    May 24, 2001
    18,373
    Herts, England
    +5,459
    its a good remote to start off with, ideal for basic function, but as they say, its no pronto.....my advice, save up a little longer and treat yourself to a £150 pronto, worth every penny!
  9. adrianwi
    adrianwi
    Apr 9, 2006
    191
    Linlithgow, West Lothian
    +5
