Anyone found the Yamaha RX-V750 in UK, or purchased from Europe?
Discussion in 'AV Receivers & Amplifiers' started by alanfcross, Mar 30, 2005.
Tags:
  1. alanfcross
    alanfcross
    Looking for the Yamaha RX-V750, but it seems the UK only does the amp version (DSP-AX750). Has anyone found the RX in the UK? Or, has anyone successfully bought one from Germany or elsewhere in Europe? Which company? Good service? Any compatibility problems? Which mains connectors does it have?
    Thanks as always for any guidance in this.
  2. Parklife
    Parklife
    Jun 9, 2004
    566
    28
    +33
    There are numerous threads on this. I got my 750 from Germany. http://www.technikdirekt.de/ for about £300. Got delivered within a week. Manual in English. Cut off the German put and wired on a UK plug. Easy!!!
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,751
    London
    +1,075
    Krish AV were doing the European version a while back.
  4. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +5
    The European version of the Yammy is different from the UK version. Firstly theres an improved power supply for the UK version, therefore making it louder than it's European counterpart. The sound is also tuned specifically for the UK market. Don't even bother comparing the two!!
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,751
    London
    +1,075
    But the European model does have a tuner which is absent on the UK model!
  6. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    My friend has the UK version of the 750 and I have the German one. The manual is identical, and we can't tell any sound difference at all. The only difference we can see is the tuner. Whatever 'sound tuned specifically for the UK market' means is anyones guess! Does the rest of the world have different ears to us in the UK? This is made even more irrelevant when using pure direct which bypasses the processing.
  7. alanfcross
    alanfcross
    Sunil Banga,
    What is the basis for your statement about the power and sound differences? Do you have knowledge of the manufacture or repair of these things, or have you carried out A/B listening tests?
    The inclusion of a tuner means that the unit does not need tuner phono inputs. The positions on the back of the RX unit are taken up with video monitor outputs - one composite and one S-video, which I will probably find more useful than the built-in tuner!
  8. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +5
  9. alanfcross
    alanfcross
    Thanks, Sunil Banga, it makes an interesting read, perhaps enough to steer me back to the DSP! I just hope that Yamaha don't tout this stuff, and use the higher spec parts in the early models, and then drop back to the RX spec components when the reviews are all done and dusted. They wouldn't ... would they?
  10. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +5
    I hope not but mine's safely in my rack!!! :thumbsup: Then again, I did pay full RRP for it when it first came out :oops: Bought it completely blind before even reading any reviews but couldn't ask for more now :clap:
    By the way, you're better off buyin the DSP anyway because you'll be able to buy a separate hybrid FM/DAB tuner which will be of a much higher calibre than that in the RXV. Track down a heavily discounted one!!
  11. alanfcross
    alanfcross
    Not sure I need a radio tuner at all, with Freeview radio channels and everything on satellite as well! I think FM's only future is in the car! I can't help thinking that DAB is going nowhere - in the home you've got digital alternatives, and in the car who needs that last ounce of quality?
  12. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +5
  13. Tejstar
    Tejstar
    Dec 4, 2002
    22,751
    London
    +1,075
    You do realise the 757 is coming out very shortly?
  14. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +5
    So the 750 should get discounted further. The 757 is likely to only have the added tuner with no further upgrades hence it still being 75 not 76. I would still go for the 750 if you are going to use Sky Digital radio as you say.
  15. sanxion
    sanxion
  16. sanxion
    sanxion
    I've been looking the web site and I haven't seen if they sell or not items to customers outside Spain. If somebody is interested I can ask them.
  17. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
  18. Tejstar
    Tejstar
    Dec 4, 2002
    22,751
    London
    +1,075
    I'm sure these guys don't ship to the UK last time I checked.
  19. ktng
    ktng
    May 9, 2004
    172
    16
    UK
    Just found the RXV750 on sale at Pixmania - not as cheap as importing from Germany though.
  20. Worm
    Worm
    Mar 4, 2003
    246
    +8
    Parklife, it is on the site now for about £267, what was the delivery charge and are there extra charges suc as vat/customs.
    Also I believe Yamaha UK honour the warranty.. is this true?
    TIA
  21. Tejstar
    Tejstar
    Dec 4, 2002
    22,751
    London
    +1,075
    There is no VAT or customs as you’re importing from within the EU.
    Yamaha UK will honour the warranty too. :)
  22. Worm
    Worm
    Mar 4, 2003
    246
    +8
    Thanks for the prompt reply. Thats good news think i will place an order to see what the delivery charge is gonna be.. Thanks
  23. Parklife
    Parklife
    Jun 9, 2004
    566
    28
    +33
    Tejstar answered the VAT and warranty Q.
    The delivery was €22. Took about 5 days. Superb!
  24. Worm
    Worm
    Mar 4, 2003
    246
    +8
    Thanks have just ordered £282.. not bad for the High spec Its replacing my 640 which have sold to mate for £180.. so well happy!! :thumbsup:
  25. harpal
    harpal
    Mar 1, 2004
    South Tottenham
    I have ordered one too
    :clap:
