The 507 is somewhere between a 3550 and 4550 in terms of power. According to a dealer, the 507 does use some updated components found in the newer/higher range h/k products, though.
hi all
got everything sorted now rear speakers levels were to low used spl meter ,all is running fine.
witters what speakers are you using for fronts please.
spy hk 507 might not have all the knobs/buttons of say 3802 /pioneers /etc and its styling may not suite eveyone ,but in reality for its fairly modest cost soundwise sterio /av and what might seem modest output 50x7 it runs seven speakers (av) use ok.
it sounds quite powerfull at modest volumes my room is not massive 3.5x4 meters.
hornydragon does anyone know the remote codes for the original pace (sky digibox) the ones in booklet do not control my sky reciever.
sorry to but in on ya thread . i soon to be getting a 3803 but was wondering if there are any other/cheaper amps with audio delay ?
as this is the main reason i have chosen this amp
On Screen Display. It makes setting up an AV receiver much easier, as all setup menus are displayed on your tv. You will need to connect the amp to you TV via monitor out
New HK range is on its way and i expect the audio delay to feature but sure at what level. I will know more once i have been to the launch which should be next month i hope.
Has anyone tried using the multi room feature to bi-amp their fron speakers? Im not interested in 7.1 yet (room too small!) and multi room is a bit much too, but biamped fronts would be nice
Just to update you, sorry for tagging on this thread.
Have just struck a deal with Spligsey for HK 8500 for £900, no demo but having scoured the thread seems the only way to go, especially at the price. Many thanks to everyone on the forum.
