Anyone ever taken apart the MCE remote receiver?
Discussion in 'Microsoft Windows' started by deksawyer, Aug 4, 2005.
  1. deksawyer
    deksawyer
    May 26, 2005
    1,634
    Fife, Scotland
    +132
    Going to look into this to fit it in a case, but was curious to know if anyones ever tried this and what problems they ran into.........
    cheers
    D.
  2. OneEleven
    OneEleven
    There's a thread here about fitting one into a mediaPC.tv case.
    Skunkpipe i think is the person to speak to who did this. I'll have a look to pop the thread back up, but I'm sure Skunkpipe will be along soon as he appears to be here a lot
  3. comedypedro
    comedypedro
    Well I never took it apart but Ive got it fitted into a 3.5" bay (floppy drive bay)
  4. Skunkpipe
    Skunkpipe
    Yup - what you want to know?
  5. deksawyer
    deksawyer
    May 26, 2005
    1,634
    Fife, Scotland
    +132
    Ideally I'd like to see some pics of it in bits if poss??
    D.
    **EDIT** Found them on your thread, thanks mate!
  6. Skunkpipe
    Skunkpipe
    a very small torx driver is needed to take it apart - it you don't have a suitable one then you can unclip the front IR window and cut throught the screw posts with some wire cutters/similar. instruction on how to conect to the m/board header are in the other thread
  7. stuartmc
    stuartmc
    Oct 20, 2004
    203
    16
    Reading
