Anyone else running a CRT projector here?
Discussion in 'Desktop & Laptop Computers Forum' started by AndyFov, May 25, 2004.
  1. AndyFov
    AndyFov
    Nov 20, 2002
    1,472
    March, Cambs
    +45
    I'm struggling with the setup!
    I have a NEC 9PG crt projector, it's multiscan, and can take anything up to 1600x1200. Max refresh rate is 93Hz. I'm trying to work out what I need to do to best hook it up to my projector.
    The PC is nothing special, it's a 850mhz athlon, with WinDVD4, and a Nova T freeview card. So far, while not really knowing what I'm doing, I've setup Powerstrip to output a 1280x720p signal, and used advanced timing settings to squidge it down to the correct shape - or thereabouts.
    When running Wintv, I was kinda hoping that the fullscreen mode would be just that. Instead it initally resizes to full screen, but then shows a 4:3 image in its place. Anyone know of a fix for that? How do you get a fullscreen 16:9 image out of a Nova T?
    I'm sure there must be a better way, because as things stand I'm finding it all a bit clunky, and not especially useable. I know it's only early days, so I'm looking for a few pointers from hardened HCPC users to help me on my way!
    TIA
    Andy
  2. dek1965
    dek1965
    Jan 20, 2003
    389
    Heysham
    +6
