Anyone else having issues with freeview retuning since the June 22 update?
ashyt16
It seems there has been a major update on 22nd June that has removed and changed many channels.
I was getting a notice on some channels saying I needed to rescan.
I did but now all channels are in alphabetical order instead of the normal freeview order.
Nothing I have tried including factory reset countless times has solved the issue.
The only way I can get the channels in the right order is to move them manually.
I use a software called CHANSORT.
Have they muffed something up with the update or is the TV up the duff?
Anyone else having an issue retuning?
TV is a UE49RU7300KXXU
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
