Anyone else have Philips Q50 with audio sync problems?
Discussion in 'Blu-ray & DVD Players & Recorders' started by codlord, Jul 1, 2003.
  1. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    I have the import Philips DVD-Q50 with PAL/NTSC progressive scan and I have noticed audio problems where the audio is slightly out of sync with the video.
    I initially put this down to iffy DVD's becuase it seemed to be random or I only noticed it now and again but it seems to be only when the DVD is playing on the second layer.
    Example: Region 2 of Jay and Silent Bob Strike Back - the first scenes on the disc no problem with audio, but go to the later scenes which are after the layer change and the audio is noticably out of sync.
    I have tried upgrading to what I believe to be the latest firmware but did not change anything. Anyone have the same problem or got any suggestions?
    I used this firmware:
    http://www.geocities.com/dd_dts/firmware.htm
    Also found this list of firmware but was not sure if this was newer than the above link or not:
    http://philips.ianc.net/downloads.shtml
