Anyone come across this JVC 32A60
Discussion in 'LCD & LED LCD TVs' started by Glenagoolie, Aug 15, 2005.
  1. Glenagoolie
    Glenagoolie
    Jul 21, 2005
    164
    +5
    Hey,
    found this on a website and looked it up on JVC.co.uk.
    Has anyone come across one , know whether it does 720p via
    the component and whether the scarts are RGB ?
    thanks
    Ronan
    • 10W Total RMS Output
    • Teletext: 10-page Memory (Level 1.5)
    • Supplied with tabletop stand
    • NICAM Stereo
    • 2 SCARTs
    • S-In, AV-In
    • W-XGA (1366 x 768 pixel) panel
    • Component Input
    • PC input
    Key Specifications
    Panel: W-XGA
    Resolution: 1366 x 768
    Contrast Ratio: 1000:1
    Brightness: 500cd/m2
    Response Time: 7ms
    Dimensions (inc. tabletop stand)
    Width: 82cm
    Depth: 31.4cm
    Height: 62cm
    Weight
    19.7kg
  2. hughesy
    hughesy
    Jan 22, 2005
    846
    Irish in Oz
    +13
  3. hughesy
    hughesy
    Jan 22, 2005
    846
    Irish in Oz
    +13
  4. EatMyRam
    EatMyRam
    The LT-32A60S have DVI input and is HD Ready, but not the LT-32A60SU model.
