Anyone changed a Megane II head unit/speakers?
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Brogan, Jul 23, 2004.
  1. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +481
    Has anyone changed any of the standard fit Megane II head unit or speakers?
    I'm trying to find out what the front speaker wiring polarity is.
    The oem speakers have a proprietary fitting and the spades are the same size so I can't work it out from that.
    There's nothing in the manual or on the oem speakers/wiring to indicate which is +ve or -ve.
    Renault won't provide me with the information unless I pay them! :censored:
    Anyone know?
  2. JiMbOb_74
    JiMbOb_74
    Hi, I am a professional installer working for hyde park corner(we do argos halfords etc)
    The best way of working out the polarity is to remover the radio and the speakers and use a multimeter or test light to "buzz out" the cables. With no speakers or radio connected you should easily be able to work out which is pos/neg at the speaker.Personnaly I would wire it up and listen for phase.. but not everyone can tell when its wrong!
    Hope this helps
    James Baker
  3. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    Hi James - thanks for the advice.
    TBH, that's a bit too much work just to work out which is which and is my last resort option.
    I do have it wired up presently but I can't actually hear that much difference :confused:
    Then again, my ears aren't what they used to be...
    I guess if the worst comes to the worst then I can buzz out the wires but I'd rather not.
    P.S. Never buy a Renault :rolleyes:
  4. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    James, i must admit you've lost me with this one. I can't see how using a test lamp will show anything more that continuity and to what ends are you using a meter to find the speaker polarity ?
  5. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    Well it seems I may have worked it out...
    I took the head unit out and as I suspected, there was just a plastic block of cables with no information at all.
    I noticed that the speaker wires for the fronts and tweeters were the same colour and from the same terminal on the back of the head unit.
    I removed the tweeters and luckily, they are fitted with a suppressor.
    As the new Kenwoods are also fitteed with a suppressor on the +ve terminal, I assumed this must also be the same for the tweeters.
    So I wired up the same colour wire on the tweeter suppressors to the terminal with the suppressor on the Kenwood.
    After all that, I got a reply from Renault saying they were looking into it after telling them where to stick their customer services so I may even get the 'official' answer soon...
  6. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Hi Brogan, your car should have a standard ISO plug for the stereo. This is an industry standard and should be very easy to find the wiring diagram on the web.
  7. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    Thanks Mylo - I'll do a search.
    Are you sure though....it is French after all...;)
  8. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    My pug 306 says hello ;) :D
  9. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    Don't you mean bonjour....;)
  10. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Oui :rotfl:
