Anyone bought a sony hd3 from amazon ?
Discussion in 'Headphones, Earphones & Portable Music' started by Rikwaller, Jun 10, 2005.
  1. Rikwaller
    Rikwaller
    Mar 21, 2005
    2,269
    +113
    Hello,
    Has anyone bought a hd3 from amazon, did it come with power adapter?
    The spec on amazon does not mention one but the sony site does ?
    Also do you think they will send one with a serial that is under recall ?
    Simon :thumbsup:
  2. HMHB
    HMHB
    Nov 11, 2001
    25,510
    Nottinghamshire
    +3,850
    It might be worth sending a quick email to Amazon to ask them those questions, then at least you have evidence of you mentioning the affected serial numbers if you are unlucky enought to receive one.
  3. watchinthewheel
    watchinthewheel
    dont worry i got one from amazon and it came with everything you need, power and usb adaptor and ss software.
  4. rigger123
    rigger123
    Feb 1, 2005
    77
    Norwich
    I also got mine from amazon with everything included. i ordered mine two months or so ago and the serial number is well past those that have been recalled so my guess is that you should be fine.
    good choice of player btw.
  5. rallyfan_1986
    rallyfan_1986
    Mar 3, 2005
    13
    I ordered one from Amazon last week, recieved it on monday. Its got everything it needs, only comes with sonicstage 2.3, so that will need updating. The serial number is not in the recall range on mine.
  6. Rikwaller
    Rikwaller
    Mar 21, 2005
    2,269
    +113
    Hey all,
    Thanks for all your help, It was dispatched yesterday, I cannot wait for it to turn up!!!
    Simon
  7. meddyliol
    meddyliol
    May 11, 2005
    45
    :thumbsup:
    I also bought mine (and my wife's) from Amazon, this after returning the HD5's. Is was nice to see something actually made in Japan instead of one of those other far east countries.
    :devil:
  8. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    technically speaking meddyliol, you havent been meddwl lately and japan is kinda east..not just east but very east! so far eas tits........far.
    ok ill shut up now :)
  9. dowlinmp
    dowlinmp
    with the hd3 what was the recall about? Saw some on amazon for£150
  10. watchinthewheel
    watchinthewheel
    it was to do with a problem between the buttons and the pcb, i never had a fault and mines in the serial number range (touch wood) so i dont think its athat big an issue, plus they are being replaced, and i doubt amazon are still seeling effected units anyway.
