Anyone been to the the USA? - Power question
Discussion in 'General Chat' started by Doctor Smith, Apr 26, 2007.
  1. Doctor Smith
    Doctor Smith
    Apr 3, 2007
    2,500
    Loughborough
    +270
    Im going to Orlando in 3 weeks and was wondering if I use the plug adapters 2 pins in and 3 pins out for uk plug will i still get power to charge camcorder batteries and the most important thing will my wifes hair drier and staightners work, or will I need a power converter which cost £25
    Thanks all
  2. indianwells
    indianwells
    Jul 14, 2006
    2,093
    116
    Anna Kournikova's Bicycle Seat.
    +1,166
    I wouldn't bother taking the curlers and hair dryer. Just buy them over there. Cheap as chips. A normal adaptor will be fine for the camcorder, it just takes a little longer to charge.
  3. MickEP
    MickEP
    Dec 8, 2005
    499
    Blackpool
    +96
    I was there Last Year and didn`t have a problem with chargers etc. Can`t comment on the hair straightners, as I ain`t got no hair :D
    But my Daughter tried to buy some GHD`s over there and the Salesman said that you can`t get them over there because of a voltage issue, as GHD`s are only 240 v
    If its your first time in Orlando you will Love it :smashin:
    Have a great trip!
  4. booyaka
    booyaka
    Sep 26, 2002
    11,050
    +3,577
    just back from new york
    missus had no issues with hair straightners - worked fine plugged into a £2.99 travel plug adapter thingy from boots. (GHD thingys)
    Hair dryer also fine also.
    Only complaint was the "water is different here so my hair is more frizzy!!":rolleyes: :rolleyes: :rolleyes:
  5. Reepicheep
    Reepicheep
    Aug 5, 2002
    583
    28
    Leicestershire
    +51
    Biggest problem I had was keeping the UK plug and adapter in the wall socket!
    The US sockets are rubbish. I ended up having to prop it up using a phone book and Gideon's bible just to keep it plugged in LOL
    Make sure you check the voltage operating range on any chargers you have. Most have a wide operating voltage range these days (90-250VAC), but some still only specify 230VAC.
  6. Doctor Smith
    Doctor Smith
    Apr 3, 2007
    2,500
    Loughborough
    +270
    Thanks all
