Anyone any idea on these?
Discussion in 'Projectors, Screens & Video Processors' started by sinbrad, Jun 2, 2004.
  1. sinbrad
    sinbrad
    Hi all, Have been handed these by a friend who got them from a friend and
    apart from knowing that they are supposidly brackets for fine
    tuning the focus on 8" crt's I'm in the dark. Does anyone have any info on them?
  2. BeerDrinker
    BeerDrinker
    Jul 5, 2002
    63
    Surrey
    They could be from a Barco 800 series - perhaps Roland would recognise them straight away. (I am at work so can't look to check). Incidentally the blue tube mount in my Barco happens to be cracked and damaged..............if the are what we think, and you need a new home for them...........
    Regards
    Bob.
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I recon these are from a really old Barco Graphics 800. The adjuster on the top will give top / bottom focus. the one to the side will then achieve a sort of left/right. hence giving full focus adjustment (schiemflug)
