Anyone able to help with region hack for LG 4210?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Bozza, Jan 14, 2002.
  1. Bozza
    Bozza
    Oct 6, 2000
    75
    UK
    I've just bought one and can't find any info any where on how to hack it. Any help would be welcome along with any problems anyone has had with them. Also is the Macrovision disabled when itis multi region. Thanks in advance.
  2. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    I got this off another site so I don't know if it works or not, but it's worth a go.
    1. Turn Player on with no disc inside
    2. Press pause on the remote control
    3. Then key in 3 1 4 1 5 9
    [CODE -- will then be displayed on the player display]
    4. Key in desired Region number
    [0 for Auto Multi Region, or manually select 1 to 6]
    5. Then Press Pause again
    6. Turn off player and wait 5 seconds, then back on again.
    If you are having problems getting the hack to work, try pressing stop on the remote before you press pause for the first time.
  3. jasper catt
    jasper catt
    Shoka
    If you got this hack of www.dvd-reviewer.co.uk then it does work.
    I had to enter in the details a couple of times before it accepted .If you leave the region selected to region1 it will also play region 2 discs as well !!.Mines set to R! all the time and plays all my R2 discs.
