Anyone a Washing Machine Expert Around Here ?
Discussion in 'General Chat' started by loonatic, Oct 26, 2005.
  1. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    My washing machine has just stopped and started beeping at me :mad:
    It's a Hotpoint (Model #9949 if anyone's interested) and it shows an error code E30 which seems to relate to the motor which makes sense as all seems well when you start it until it's time for the drum to move.
    Had a quick search on the net and a new motor will cost around £100 :eek:
    Anyone know if replacing the motor will sort it out ? or even if it's worth it ?
    Would be looking at about £500 for a new one...it's a washer dryer you see.
    Cheers, Lee
  2. smeghead
    smeghead
    Jan 21, 2001
    96
    KENT
    +3
  3. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,650
    38
    +13
    i aint even at expert at washing my clothes in one, let alone repair :p :rotfl:
  4. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    Check round the back, and see if the belt is still attached correctly, or snapped, as this will cause the motor to stop working, and give the error code you mentioned.
  5. mps
    mps
    Oct 16, 2001
    1,685
    London
    +63
    Check the brushes on the motor.They are easy to replace and dont cost much.
    :thumbsup:
  6. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,286
    Manchester
    +763
    We had a worn brushes fault with simlar symptoms on our washing machine 3 weeks ago whilst I was working in Ireland.
    Local guy with "no callout charge" changed them for the missus in my absence - 60 quid for 10 minutes work!
    Should be a simple DIY job (take the usual precautions including unplugging it from the mains, of course).
    Chris Muriel, Manchester.
  7. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    Thanks for all the replys :thumbsup:
    Have posted a query on the UK White Goods forum to see if they have any more ideas.
    The belt looked fine but will double check.
    I will have another look at the motor tomorrow and try and source some new brushes...it's got to be worth a go...any idea if local places might sell 'em ?
    Cheers, Lee
  8. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    Definately the brushes. Worn down too far.
  9. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    I'd go for the brushes too.
  10. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    Just a quick update...I sourced a set of brushes locally as mine did indeed look a little worn, especially compared to the new ones, but after fitting them the problem persisted.
    So I set about testing all the wires and connections and then the two PCBs which after a couple of hours led to the discovery of two dry joints on one of the PCBs...so after a spot of soldering to make good the joints everything was put back together and all is now working fine.
    Have since done four loads of washing to catch up without a hitch.
    Cheers, Lee
