Anynet+ settings not saved
cwroalifg
I use a PS4 and a Google chromecast on my TV and have anynet + switched on. The issue I'm having is that the setting for turning the TV off when you turn off a connected device keeps reverting to "no". I can change this to "yes" and it'll work but within a few hours or the next day it'll revert to "no" again.
It's an old model from 2011 and everything else seems to work ok. Any suggestions?
JayCee
I regularly come across those symptoms on Samsung TV's of that vintage.
There's no fix for it that I'm aware of.
cwroalifg
That's annoying but thanks for the reply. Might have found a workaround with the chromecast as I can set that to turn tv off via ir
