Anynet/HDMI-CEC compatible LCDs?
Discussion in 'LCD & LED LCD TVs Forum' started by chrisbarns, Sep 12, 2007.
Tags:
  1. chrisbarns
    chrisbarns
    Since my Samsung LCD seems to be unrepairable (digital-out audio fault), I'm thinking about swapping it for another 32" LCD. However, the thing I like about it is the Anynet system, which communicates with my Samsung DVD player. From what I can gather, Anynet is basically Samsung's implementation of HDMI-CEC, so I was hoping it may work with other brands that support HDMI-CEC.
    My question is - is there a definitive list anywhere of TVs that support HDMI-CEC?
    Cheers,
    Chris.
  2. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    The latest sony tv's also have Bravia Threatre sync similar to anynet
  3. JinJin
    JinJin
    May 26, 2007
    25
    also the newer panasonic's have viera link which is their implementation of HDMI-CEC.
    interoperability between these different implementations should not be an issue.. but in reality that could be another story!
  4. chrisbarns
    chrisbarns
    Thanks..
    So we have 'Bravia Theatre Sync' and 'Viera Link', which are at least implementations of HDMI-CEC. Testing interopability could be interesting!
    Are there any others?
    Now all I need to do is find a TV with roughly the same dimensions (without stand) to fit into the nicely designed shelving system I created to house a Samsung LE32R87BDX... I don't suppose anyone actually keeps a chart of specs comparing different TV's standard dimensions/features/etc? If not, I think I might have a go at creating something.
    Cheers,
    Chris.
  5. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    So you want a similar to the R87 tv?One is the Sony KDL-32S3000
  6. c3ham
    c3ham
    Sep 29, 2004
    203
    +19
    jvc dp8 and dv8 support cec
  7. chrisbarns
    chrisbarns
    Yes, that does indeed look like the TV I want! I'm not sure if it supports HDMI-CEC though.
    Cheers,
    Chris.
  8. MrLOL
    MrLOL
    Nov 13, 2005
    403
    28
    Wakefield
    +31
    Samsung F86 series LCD also supports it.
  9. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    It can 100% supports HDMI-CEC
  10. RockySpieler
    RockySpieler
    May 23, 2005
    1,661
    Snaking the Lineup
    +115
    According to the Spec's the new Toshiba XF and Z (and probably ZF) series have HDMI-CEC, as does their latest Qosimo HD-DVD laptop.
