Anybody using PLIIx Music for TV?
Discussion in 'AV Receivers & Amplifiers' started by darrylp, Sep 11, 2004.
  1. darrylp
    darrylp
    I'm finding that my sound seems to be better using PLIIx Music for TV viewing and I don't know why.
    Is anybody else doing this or have they tried it?
    If so did you adjust any of the parameters?
    Darryl :confused:
  2. Jules
    Jules
    Oct 11, 2000
    5,581
    134
    +1,039
    I've noticed my preference for music/cinema modes of PLII seems to depend on the speaker delay time settings on my amplifier.
    When correctly set, the Cinema option sounds best to me. But if I increase the delay to the centre speaker then the Music option sounds better. weird.
    Personally, I never use PLII music as it sounds dull and lifeless to me.
    Neo 6 Music though is crisp and vibrant, and I do us that occasionally for music programmes like MTV.
    Generally though, I use the Cinema modes for nearly all viewing material.
  3. darrylp
    darrylp
    Hi JUles
    Do you think I should try decreasing the Movie delay time?
    I'm using PLIIx for dialogue only and find the Music profle clearer!
    Darryl
  4. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    What exactly does PL2 Music and Cinema actually do to the sound?
    I don't usually use DSPs but I have found the Hall setting on my AVR200 is excellent for MTV etc.
  5. pez
    pez
    May 1, 2004
    776
    Newport
    +27
    position of the centre chanel between the left and right fronts is different between cinema (all centre) and music (spread around) i think, and then within music you can stretch it (panorama) around the rears too.
    pez
  6. Jules
    Jules
    Oct 11, 2000
    5,581
    134
    +1,039
    Only if is correctly set thereafter.
    Most modern amplifiers let you set delay times by telling it the distance between the listening position and each speaker. These settings are then applied accross all sound modes.
    I'd just measure up and set it accordingly. Then use the modes that sound right to you.
    I think there's a compromise in getting 5 channels of audio from a 2 channel source, and it probably involves some kind of 'phase shift' between the channels. By adjusting the delay times, I reckon you can probably compensate a little for this, but ultimately true 5.1 soundtracks would then suffer.
  7. darrylp
    darrylp
    And does anybody else use Music for regular TV?
    Darryl
  8. SKA.face
    SKA.face
    Music is better just using the 2 fronts(stereo),that's how it was recorded,so that would be how it should be replayed,putting effects on music is dire.
  9. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Listening to a cd is very different to watching a music video. I find that listening to the latter in stereo doesn't work because the sound seems distant from the speakers. Using dsp utilises the centre speaker and I can associate the sounds with the images.
