Anybody use video up-conversion on AX-5ai?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by MikeFish, Dec 2, 2004.
  1. MikeFish
    MikeFish
    Has anybody here used the video up-conversion on a Pioneer AX-5ai (S-video to component)?
    I have my Sky+ connected via S-video to my amp, and the amp is connected to the plasma using components. When watchnig Sky the picture is quite badly deterriorated compared to when using s-video all the way through.
    So what I want to know is, is there a problem with my amp or is it just a poor up-conversion?
  2. recruit
    recruit
    Mike it is not unknown to have a poor quality picture after the signal has been switched thru you're amp as you will get a loss of signal quality as it goes thru the amp and to you're TV, it also depends on how good the signal was in the 1st place, is it only the Sky that you are converting or does it do it on all conversions?
    John
  3. MikeFish
    MikeFish
    Oops! Just noticed I was in the wrong area when I posted this thread, I meant to post in "Integrated Ampifiers". :blush:
    Mods, feel free to move to correct section (might get more attention anyway!).
    Recruit
    The DVD is connected to the amp using components so the picture from that is great. To be honest I haven't really watched anything else through it yet. Will power up PS2 and see how that looks (that's the only other thing connected with S-video).
    Thanks.
  4. MikeFish
    MikeFish
    It seems to be doing the same thing with my PS2, although maybe not as bad. Looking at it I think it is just a case of bad conversion. :mad:
  5. recruit
    recruit
    I think you might be right but maybe have a word you're dealer that you got it from and see if they have any suggestions... :)
    John
  6. MikeFish
    MikeFish
    Will do.
    Thanks for your help John.
