Anybody tried pinnacle usb moviebox
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by motty, Jul 24, 2003.
  1. motty
    motty
    Aug 11, 2002
    I was thinking of getting this piece of kit because i use 8mm
    camcorder and so does my 2 sisters,I have all the software i need
    but i need to get the footage onto my pc.
    I tried the belkin usb 2 dvd creator but it kept crashing my system.
    And avermedia usb2.0 dvd ezmaker says may kt400 doesnt work with it.So i am buggered basically.
    I know about canopus advc 100 but its out of my price range and i dont want to take a chance on a second hand unit.
    So any help
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,354
    Rainham Essex
    +2,441
    My USB ADSL modem kept crashing my system, until I changed the USB cable. Since then I have had no problems.
    Might be worth a try as a USB cable is cheaper than a new capture device.
    Mark.
