anybody has used a Sony VTXD800U FreeView Digital Receiver
Discussion in 'Freeview & YouView' started by Manitu, Nov 18, 2004.
  1. Manitu
    Manitu
    iam new to freeview allways used ntl cable
    is the Sony VTXD800U FreeView Digital Receiver a good option and can i connect it to a yamaha av amp
    pls lmk what you think ?
    thanks for youre help
  2. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    IMO the Sony & Pioneer are regarded as the best. I've already got the Pioneer but will be getting the Sony soon as i need two tuners.The Pinoneer had optical out,i'm not sure on the Sony.............
  3. dvdsubtitles
    dvdsubtitles
    I dont think the Sony has optical out. I had to choose between the Pioneer and the Sony, I went for the Pioneer because a) It has optical out and b) the rest of my stuff is Pioneer as well. However, I suspect the Sony probably has better picture quality. From the screenshots I've seen, the Sony has a much better programme guide and user interface.
    Cheers,
    Mat
  4. Wilf
    Wilf
    Jan 11, 2001
    364
    Staffordshire
    +6
    The sony does have optical out. It takes the mini toslink adapter. Great digital sound, fantastic picture, fast menus and full support for the 7 day epg. It is also well supported by sony with frequent on-air software updates. No rf modulator if you need to send freeview to another TV but I highly recommend it.
  5. Manitu
    Manitu
    Thanks guus for all youre replys but has on of you conected the freeview box to a av amp ? and how ?
    ive got a Panasonic Widescreen has build in Surround Sound wich i dont use
    would like to watch Tv through my Seperate 6.1 speakers
    got a Yammaha Amp
    wich freeview box would be the better option for me the Pioneer or the Sony ?
    thanks
  6. Wilf
    Wilf
    Jan 11, 2001
    364
    Staffordshire
    +6
    Both will. Digital Optical lead from freeview box to one of your optical ins (I take you have some still unused) on your AMP. That's how mine is connected to my Marrantz AV amp. BTW Digital radio from the Sony sounds fantasic too :thumbsup:
  7. Manitu
    Manitu
    thanks for your help thanks alot will defo get the Sony
