Anybody got Xbox live working on btopen?
Discussion in 'Xbox Forums' started by Respectamonkeee, Jan 5, 2003.
  1. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    512
    16
    Aylesbury...where the Ducks live!!
    im using the orginal fish modem that bt supplied with ADSL when it 1st came out.
    since it contects to the pc via a usb socket i,ve already had to get rid of 1 router that i bought to use my dsl on the net work...
    I've now bought a speedtouch 530 router with a usb socket but im not 100% sure that this will work as well
    Has anybody here playing Live on a openworld account and with the fish modem???
    Ta for any help
    Monkeee
  2. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    Monkeee,
    I'm not a networking expert, so can only tell you what worked for me. Initially I used the Alcatel "fish" and connected the Xbox to a network card in my PC, having enabled ICS. This worked fine, but I fancied going for the router option for added convenience.
    So, I ditched the "fish" and bought a Netgear DG814 - which is a combined router and ADSL modem. It was dead simple to set up and has worked without a hitch for weeks.
    I'm not familiar with the 530, but having looked at DSLsource I'm with you when you say it might not be what you need!
    EDIT: Having looked again at the speedtouch site the 530 appears to be a combined modem/router, so you should be fine with it.
    EffTee
  3. Dom H
    Dom H
    I have the 510 v4 modem/router and it works perfectly, forwards all ports for you if using NAT, totally plug n play.
  4. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    512
    16
    how much did you pay for the 510???
    is it a modem as well as a router??
    Im not 100% sure if the 530 is a router or a modem?????
    this is doing my head in..as i got rid of a brandnew dlink router on saturday
    HEEEEEEEEELP
  5. Bonesy
    Bonesy
    Feb 22, 2002
    1,143
    Wiltshire
    +27
    I signed up for xbox live yesterday - using the speedtouch 510, with static IP addresses configured - works fine.
  6. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    512
    16
    well all being well the 530 should work ok....
    does anyone know if i can plug the router into a net work so more pc's can have net access?
