Quantcast
Any way to fix a faulty subwoofer cable
daveb975
I have got a strange problem with a subwoofer cable. It seems to work fine, but if the plug at the SW is touched it gives a really loud, distorted signal through the sub. Sometimes, it even happens without it being physically touched.
The plug itself looks fine and I can't see any physical damage to the cable.
Swapping the cable out solves the problem, but the original cable is buried deep under carpets/underlay etc. so I'd rather use that one if I could.
Has anyone had similar, and if so is there anyway to fix it?
daveb975
How good are you with a soldering iron?
Not excellent, to be honest! This is a cheap, sealed plug anyway. I reluctantly bought it at the time, because it was the only one that was thin enough to bury properly.
I have seen a QED one that looks as though it would do the job, so I might have to replace with that.
Is this likely to be a loose connection inside the plug?
Joe Fernand
AVForums Sponsor
Could be damage anywhere along the length of the cable - any problems with mice etc getting into your walls?
You could try chopping off the RCA and replace it with a solder on plug.
Joe
daveb975
Joe
I pulled the cable out in the end. It looked undamaged all along its length, so it must be something in the plug.
I moved the sub closer to the amp for now and connected it with shorter cable. I’ve picked up some hum again, even though this is a higher quality cable that was fine in my other system.
Some experimentation required I think!
daveb975
I’ve heard a few postive reports about the Audioquest range of subwoofer cables with the integrated ground lead.
I won’t be able to use anything that size unfortunately, but if I tested one and it worked, is there any reason that a long earth lead running separately to the main cable wouldn’t do the same thing?
Similar threads
