Right I've got myself a little dilemma here..
I'm currently using the passthrough RGB signal available on my digibox (thank Philips for one RGB scart...
). The problem is I would like to control when the pass through is actually enabled. At the mometn I have to physically disconnect the scart (better than rumaging behind the set but far from ideal). The problem is the RGB signal is continuous as its from a PC and even with the PC in standby the signal is active. I put the settings out of sync and my TV shows no image (blus screen) but I still cannot get Sky to show..
I was hoping there might be a solution to this little problem..
PLEASE HELP!!! I'm lost..:/
