Question Any way around my problem?
Discussion in 'Home Cinema Control & Remote Controls' started by DracUK, Oct 24, 2017.
  1. DracUK
    DracUK
    Apr 24, 2004
    1,135
    Hull
    +94
    Hi,I have a Hisense 49M3000 TV and a Dune 303D Media Player whos original remote codes are clashing with each other making the Dune unusable with this TV.I also have a Harmony Ultimate Touch without the hub and the same thing happens. I have been in touch with Hisense and had no reply from them
    any ideas
  2. 12harry
    12harry
    Oct 10, 2010
    4,788
    103
    London
    +390
    Move the TV /Player apart.... so the remotes only point at the one it's intended. It's a dirty-solution, but IF it works, then you can settle down to watching. You can try also putting a filter over the transmitter LED, so as to reduce its range.... although weakened batteries will do much the same, in time. I have a DVD recorder that has an IR receiver option, on a 1m cable so the recorder can be operated either direct, or having this extension.
    I'm surprised Hisense haven't come back to you, - if this is a valid combo.... There are many variations of the remote-codes - but I guess there aren't enough. It's just possible one device has an Option to use another set of codes ( this would be sensible ), so the codes don't overlap.
    The same/similar problem occurs with Wireless doorbells; if a neighbour happens to use the default settings..... which you use.
  3. DracUK
    DracUK
    Apr 24, 2004
    1,135
    Hull
    +94
    Thanks m8 but have tried all that.Phoned Hisense UK today supposed to be getting back to me.
    regards
  4. JUS
    JUS
    Jan 21, 2003
    3,434
    Plute
    +322
    On thing u could do is use the harmony with the hub and irblasters and assign each device to a different blaster. If the tv and dune have it inputs it’ll be very easy as using them normally turns off the ir receiver
  5. DracUK
    DracUK
    Apr 24, 2004
    1,135
    Hull
    +94
    Thanks for replying,I have just ordered another elite with hub (I needed another controller anyway for bedroom)so will see if that works.
    regards
  6. DracUK
    DracUK
    Apr 24, 2004
    1,135
    Hull
    +94
    Well Ive played with this for hours and still no joy.Looks like a change of TV is needed or different Media Player.Shame really as I love the Dunes.
  7. DracUK
    DracUK
    Apr 24, 2004
    1,135
    Hull
    +94
    UPDATE
    Hisense says nothing can be done apart from reprogramming every remote control sold...DOH
    Anyway Ive fixed it myself......bought a Samsung tv and all is well :(
    Anyone want a Hisense ?
