Any tips/products for removing scratches?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jon Weaver, Nov 6, 2001.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,165
    Born in Bristol but now in Newport, (for my sins)
    +723
    Do you know anything which is good for getting scratches out of plastic.
    I have an unreplacable DVD which I have a scratch on.
    I normally use toothpaste on CDs. But this leaves a 'matt' mark over the spot which is millions if tiny scratches....
    But thats OK because I can then read the whole CD in and write it on a CDR
    But for DVD its different and I can't.
    I want to polish the scractch out to make it 'like new'.. The scratch is not deep (infact its more of a smudge than a scratch).. Is there a product which can polish out plastic!
  2. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,844
    72
    birkenhead
    +82
    you could try a product called crystal disc i got mine from tesco but that was a while ago.5 pound for a little tube but you only need a small amount also try a device called skip doctor.not sure what website it was on butr im sure the knowledge of the forum will help :D
  3. Guest
    Try Brasso or Duraglit wadding, works for me. You might also have some luck with jewellers rouge, test it first on a cdr, covermount, or whatever, just in case.
  4. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,165
    +723
    Tried Brasso (and Silvo) on an old CDR and both get the scratch out really nicely.
    It leaves the surface smooth.. But, its really misty!
    I had a look in Tescos and can't find any CD cleaning product.
    I wonder if there is a polish which is designed for plastics out there?
  5. encaser
    encaser
    Mar 15, 2001
    2,820
    Suffolk/Essex
    +742
  6. jasper catt
    jasper catt
    You could try using a small quantity of Autoglym (the car polish).I have used it on scratched cd's and perspex turntable covers with good effect.Work a little onto the scratch in a circular motion,wait for it to dry and then buff it off. I think toothpaste would be too abrasive hence the dull surface
  7. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,165
    +723
    I used some 'Mr Sheen' (Furniture Polish) and was surprised to find that it buffed the scratch out and left the surface 99% clear.
    So I used it ony my scratched DVD and it worked perfectly...
    I am still looking for another solution for future occurances, so will look at the products you mentioned
