Any Targa DP-5100x owners around?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Delh68, Mar 31, 2005.
  1. Delh68
    Delh68
    Dec 13, 2002
    1,034
    48
    +52
    Just bought this from Lidl, & have been trying it out.
    Came across a problem with the Co-axial Out – The Amp says it’s receiving 5.1, but it isn’t outputting anything to the Centre & Surrounds.(Definitely should be sound coming from them, as it’s ID4, & works fine with Optical)
    The cable is fine, & so is the Amp, as co-axial works perfect on my Pioneer 444
    Bitstream is selected for Audio, am I missing anything obvious before it goes back?
    Thx
    Delh68
  2. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    A few of us... several threads recently, use search if you want to read them.
    Have you done the firmware update?
  3. Delh68
    Delh68
    Dec 13, 2002
    1,034
    48
    +52
    didn't want to mess around with it, before testing the other bits - it appears to be working now, so either it's a dodgy connection, or something
    Delh68
  4. Captain Kak
    Captain Kak
    Feb 21, 2005
    27
    Hey
    How do you do the upgrade. I've looked at the read me document and it says
    1. Write the disc-image (Firmware_xx.iso) to a CD. Please take a look to the help of your burn software how to do this. Just writing the file to CD is not right!
    2. The folder structure on the created disc shoud be /lg_dvd/firmware/upgrade/lg.
    How do you do this? What is the disc image and where where can it be found? Sorry if I'm being thick here.
  5. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    Download the file from Targa webside
    In the zip file will be 2 txt files and 1 ISO (cdimage) file.
    Extract the files the ISO file from the ZIP
    Burn the ISO using e.g Nero.
    You do this in Nero using the File Open option, not by compliling a new disc !
    Don't worry about "The folder structure on the created disc shoud be /lg_dvd/firmware/upgrade/lg." as the ISO already contains all of this for you.
  6. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
  7. Captain Kak
    Captain Kak
    Feb 21, 2005
    27
    Cheers mate you are a star :thumbsup: . One other quick question. I am having difficulty playing files from within a folder. It seems to play the first one OK, then the following ones just stick and stop. Any idea how to get round this one? The burned dvd plays ok onmy computer but not on the targa.
  8. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    I have no problem playing from folders with about 20-30 files in.... sure its not the file that is the problem?
