I can't get the IR Blaster working with my Fujitsu Scaleo P 6704.
I have exactly the same setup in another room (same PC, Model etc).
Both PCs are connected to SKY (Multi Room, but different model SKY boxes). The one works perfect and the other has probs with the IR Blaster.
I've spent hours this evening.
I had it working at one point but only by actually holding the red eye a few inches away from the Sensor on the SKY box.
I've tried the obvious like switching between ports 1 & 2, switching the actual red eye cable with the other PC, switching the actual blaster box with the other PC ... but now I get nothing at all.
Can anyone suggest an alternative? is there one? Any help would be appreciated as I'm so p1ss3d off with it at the moment
