Any splinter cell gurus...help!!!!
Discussion in 'Nintendo Forums' started by Vection, Jan 12, 2004.
  1. Vection
    Vection
    Mar 23, 2002
    129
    19
    Over there!
    are there any splinter gurus who can help. I'm stuck on the final part of the Kilinatek level. I'm on the top floor heading for the extraction. I've delt with the first five guards, picked up the ammo and med kits and come to a room which has some sort of half built wall in the middle. there is only one door in and out and no window etc.
    I cant seem to make sam jump high enough to get a hand hold on the top of the wall. Even when split jumping off of a corner. There dont appear to be any pipes to climb or other means of traversing this wall.
    What am I missing????!!!!
    oh im playing on the PS2 if that makes any difference.
  2. museumsteve
    museumsteve
    Jan 28, 2001
    7,528
    3
    Nth Hampshire
    +1,007
    been a long time since I played this..but here's a link to a FAQ from gamefaqs..
    Walkthrough
  3. Vection
    Vection
    Mar 23, 2002
    129
    19
    Over there!
    thanks steve. that worked!
    I was stuck there for ages.....:suicide:
  4. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Actually, an anyone remind me how to use to lock pick as I picked this game up again last week and I cannot remember how to open locked doors.
    I do remember wiggling the analouge pad, but cant recall how to actually start using the damn thing.
    Any ideas?
    Thanks,
    Cap:)
  5. Adam M
    Adam M
    Oct 18, 2001
    724
    London
    +19
    make it the tool of selection go up to the locked door and press x I think to go into the lock picking screen.
    Rotate slowly round the analogue pad until you feel the vibration then stop rotating until that tumblers is sorted, then do the same untilt all tumblers are sorted.
